Question Problem when resetting pc. No change
bferguson4
15
I tried to reset my pc and it said the message above. Then, I couldn't access back to Windows 10. So, now I'm stuck at the blue screen. I'm looking for a way back to Windows 10.
Specs:
Monitor: Acer SB220Q bi 21.5 inches Full HD (1920 x 1080) IPS Ultra-Thin Zero Frame Monitor (HDMI & VGA port)
RAM: 2*CORSAIR Vengeance LPX 8GB (1 x 8GB) DDR4 DRAM 2400MHz C16 (PC4-19200) Memory Kit - Black (CMK8GX4M1A2400C16)
CPU: AMD RYZEN 5 1600X 6-Core 3.6 GHz (4.0 GHz Turbo) Socket AM4 95W YD160XBCAEWOF Desktop Processor
GPU: XFX Radeon RX 580 GTS XXX Edition 1386MHz OC+, 8GB GDDR5, VR Ready, Dual BIOS, 3xDP HDMI DVI, AMD Graphics Card (RX-580P8DFD6)
Motherboard: MSI B450-A PRO AM4 AMD B450 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
SSD: WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s M.2 2280 Solid State Drive - WDS500G2B0B
Hard Drive: WD Black 1TB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD1003FZEX
Colif
Win 10 Master
What type of reset were you doing? Full or keep files?
If full, I would do a clean install as iits faster in long run
On another PC, download the Windows 10 media creation tool and use it to make a win 10 installer on USB - if you don't have one now
follow this guide: https://forums.tomshardware.com/faq/how-to-do-a-clean-installation-of-windows-10.3170366/
If you were keeping files/settings. I can show you a way to move stuff off the ssd onto hdd
boot from installer
on screen after languages, choose repair this pc, not install.
choose troubleshoot
choose advanced
choose command prompt
type notepad and press enter
in notepad, select file>open
Use file explorer to copy any files you need to save to USB or hdd
Once its all moved, do a clean install.
