Problem whit amd athlon 64 x2 6000+
Kristo5380
Hello
I overclocked my 6000+ from 3Ghz to 3,2Ghz, then i runned Prime95(benchmark - 1h) and nTune(stability test)
then was everything OK
but when i clocked to 3,3Ghz, there was a problem- prime95 said in benchmark test: "Setting affinity to run helper thread 1 on logical CPU#1"
everest v2.20.405 shows, that CPU #2 is working(e.g. i`m watching movies, then CPU 2 is 100% and CPU 1 is 0%) and CPU #1 is not working(i mean, before i clocked, CPU #1 was working and CPU #2 was there to help- when i was doing something, CPU #1 showed %- e.g. 100% and CPU #2 was there, to help)
Can somebody help
BS! I´m from Estonia and my English aren't good
i hope, you understand, what`s my problem
in all reality, the Athlon 6000+ isnt even supposed to reach much higher than that, it's a horrible overclocker, 3.3 is like tops for that thing... if ur lucky...
