• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Problem with AMD 5 3600x temps
Jul 9, 2020
I need help. I Just got into PC building and i bulit a brand new PC by myself. I noticed that CPU temps are a little bit high while gaimng and also they were jumging around all over the place. The temps were somewhere in 73 to 85, it depends when it jumps. So i need help to fix it, maybe tweak the power settings or put the fans deferently. Im sorry for bad writing. It would be amazing if someone could help me via discord. :)
Furzumz
Proper
May 28, 2020
246
33
140
12
What cooler are you using?
What's the highest temperature you saw while gaming?
The newer ryzen chips seem to like to run hot and temperatures bounce around a lot with them.
GarrettL
Notable
Dec 4, 2019
1,472
326
1,190
38
If you see in the CPU section of the forum, there are two posts about the 3600 and high temps on the first page. Did you read them?
You'll likely see the same conclusion.
Furzumz
Proper
May 28, 2020
246
33
140
12
Im using the stock wraith cooler, highest temp was like 86 but only for a split sec
And i do not know how to put my fans in my case, i mean the best way.
Stock coolers usually aren't that great, its normal for them to run processors on the hot side. They're usually "just good enough" in cooling capability, not much more.
Not to say that its dangerous to use a stock cooler necessarily...just that your processor will run warm. The max temperature for a 3600x is 95C so as long as you're not hitting into the 90's it should be fine but I'd still recommend eventually getting a better cooler if possible.
How many case fans do you got? Whats that setup like?
Jul 9, 2020
My case is MSI Industrial metropolis pro, and i have 3 140mm outtakes from the back and the top and 2 120mm in the front
Furzumz
Proper
May 28, 2020
246
33
140
12
I'm not a expert on case airflow but I would assume the two fans in the front of the case should be blowing air INTO the case while the rest of the fans should be blowing air outside of the case
If it came with case fans already installed that's probably how its already setup
Jul 9, 2020
Sorry the two in the front are intakes.
Jul 9, 2020
The front fans should be okay then
The rest of the fans should be outtake fans blowing hot air out of the case
So could the problem be with the power settings or should i buy a new cpu cooler? And before i bought the new fans my temps were steady on the CPU, but with the fans they are jumping around but a bit cooler, while the case isnt hot at all.
Furzumz
Proper
May 28, 2020
246
33
140
12
The problem is from your cooler. Stock coolers aren't good. It will work, and it should be safe to use the stock cooler as long as your temperatures aren't hitting 90c or higher. But I would still recommend a better cooler because those stock coolers will run your processor hot.
When it comes to the temperatures bouncing around that's common. The newer Ryzen processors like to do that. What matters is the highest temperature you see your processor reaching. The highest you said so far was 86c which is hot but not dangerous so you can use the stock cooler if you want to but I recommend picking up a better cooler when you can.
Jul 9, 2020
https://m.gigatron.rs/kuleri-i-oprema/aerocool-ventilator-cylon-4-rgb-actc-cl3041001-363227 is this one good enough?
Furzumz
Proper
May 28, 2020
246
33
140
12
I don't have much experience with coolers so I couldn't give a good recommendation. But that Garett fellow posted some links earlier
This page in particular he linked seems to have a big list of coolers:
Keep in mind the size of some of these coolers. The "tower" coolers are big in size, so you have to make sure there's enough room in your case to fit one if that's what you get
GarrettL
Notable
Dec 4, 2019
1,472
326
1,190
38
https://www.techspot.com/article/1880-ryzen-3600x-vs-3600/
Yes.
The 3600 has about a 90 watt TDP. The Aerocool is a 120 watt, so it will work better than the stock cooler. A 150 watt TDP rating would be better.
Ryzens like to stay cool to keep the cpu core boost higher and not throttling down due to higher temps. Keep Ryzen's cool and they run like champs. Get a good cooler. The stock cooler is really a poor choice by AMD. It's insufficient when gaming.
I had the Wraith Prism on my 3800x for about a week. Nice cooler but kinda loud when3800x was gaming. It worked but they boxed that with the 3900x's and that was a pretty poor decision as well.
Reactions: Dimi3je and Furzumz
Jul 9, 2020
Yes.
The Aerocool one that i showed is a 145w tdp?
