Problem with CD Clock Radio Playing CD
sheenawv
Hello. I have a GPX CRCD6306DT CD Clock Radio that is not playing any CDs. When I put the CD into the drive, it will spin and load as if it was going to play, but then there is no sound. I know that the speakers work because they work fine when I turn on the radio. I've taken apart the radio to try to see if I could fix it by checking for loose wires and leaky capacitors, but I see nothing visibly wrong. I would greatly appreciate any help, thanks!
are you using offically created music cds or ones that you burned yourself?
if you burned them yourself, its likely that its not in a supported format.
if its official cds then check if the lens is dirty. if its not it could be hardware failure.
I am using officially created CDs from artists. I've tried cleaning the lens, and it recognizes the disk but won't play any audio.
I want to repair this myself, so the price to get it repaired is not an issue. I just want to know what part could be malfunctioning.
