Problem with computer GREEN LINES and Squares
Nov 8, 2018
6
On my green theres green lines and a lot of glitchy squares. They’re even in the bios. Sometimes I can’t start the compter because it says CPU OVER TEMPRATURE. I’m unsure if it’s the cpu or the gpu causing the problem.
yorben_vandyck
74
14
sounds like your cpu is overheating could also be a gpu problem first try another screen maybe a tv it is possible it is just your screen if this doesn't work the lines you see on screen are comming from your gpu
Nov 8, 2018
6
Can you provide system specs? Using onboard video or a discrete GPU? When computer starts correctly, are temps normal, fans working correctly, ect?
Pick as the solution
I cant start the pc
Nov 8, 2018
6
Screen works fine, should i get a new gpu and cpu
Nov 8, 2018
6
Found out I needed to change the cpu fan, because the stock intel fan sucked.
It was the gpu that was dying. Thanks !!
