Problem with GeForce 2 Pro
bill
1,834
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I picked up an old system (a Systemax with an AMD 900, 128 ram) and it had
an old ATI Rage Pro card with 8 megs of ram. I took that out and put in the
Geforce 2 Pro card with 64 megs.
It booted up fine (WinXP Pro), but when I installed the drivers and
rebooted, I lose video (monitor shuts down) after the XP Pro screen. The
Welcome screen doesn't display, which is the first screen at the desktop
resolution. I can boot up in safe mode at 800x600, I've tried the newest
drivers from Nvidia and the drivers on Windows Update.
I have a disk with older drivers on it, I'll probably try them next. I
also tried turning down the hardware acceleration, to no effect.
Any ideas? TIA.
"teqguy" <teqguy@techie.com> wrote in message
news:5bVfc.1706$L31.1606@nwrddc01.gnilink.net...
> > it had an old ATI Rage Pro card with 8 megs of ram. I took that out
> > and put in the Geforce 2 Pro card with 64 megs.
> > The Welcome screen doesn't display, which is the first screen at the
> > desktop resolution. I can boot up in safe mode at 800x600, I've tried
> > the newest drivers from Nvidia and the drivers on Windows Update.
> > I also tried turning down the hardware acceleration, to no effect.
> > Any ideas? TIA.
> PCI or AGP?
> If it's an AGP card, make sure the board supports AGP4x.
It's AGP. I'll check into it, good idea!
On Fri, 16 Apr 2004 17:15:10 GMT As truth resonates honesty "Bill"
>Any ideas? TIA.
WinXP is a very silly O/S by,"Default".It will re-boot/shutdown if it
can't figure things out(which of course it can't).
To give yourself a fighting chance when in,"safemode" go,
My Computer/Right click/Properties/Advanced/Startup and
Recovery/Settings and switch off the very very silly,"Automatically
Restart".
Yet another MS innovation to give work to Computer,"Techs" ;-)
Free Windows/PC help,
http://www.geocities.com/sheppola/trouble.html
email shepATpartyheld.de
Free songs to download and,"BURN" :O)
http://www.soundclick.com/bands/8/nomessiahsmusic.htm
> > screen. The Welcome screen doesn't display, which is the first
> > screen at the desktop resolution. I can boot up in safe mode at
> > 800x600, I've tried the newest drivers from Nvidia and the drivers
> > on Windows Update.
> > next. I also tried turning down the hardware acceleration, to no
> > effect.
> > Any ideas? TIA.
> Restart".
Shouldn't cause an issue like that.
That restart feature is only if the GUI crashes, very rarely does it
happen spontaneously if nothing is actually wrong.
> > > and it had an old ATI Rage Pro card with 8 megs of ram. I took
> > > that out and put in the Geforce 2 Pro card with 64 megs.
> > > and rebooted, I lose video (monitor shuts down) after the XP Pro
> > > effect.
> > > Any ideas? TIA.
> > PCI or AGP?
If it does support AGP4x, you need a patch to fix an AMD & XP issue
with AGP.
Normally this issue doesn't affect installation, but greatly affects
performance.
with an old system like - particularly with only 128mb ram
you'd be better off sticking in win98se or winme
"Bill" <willat@optonline.net> wrote in message
news:ywUfc.18654$rV4.2209455@news4.srv.hcvlny.cv.net...
the
> Any ideas? TIA.
