Question Problem with graphics card installed ?
Jun 4, 2021
6
Hey. I was using intel UHD graphics. Today I found old gtx 1050ti 4GB card, installed it and it doesn't working. I don't know how to set it up properly. When card is inside PC, i can't go into the BIOS. Could anyone help me?
You're going to have to list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
You will also need to include the age of your PSU. Did you use DDU to uninstall your prior GPU drivers before you dropped the GTX1050Ti in your system? Speaking of found an old GTX1050Ti, was it left outside or did you source it second hand? If either case, you might want to take the GPU to a donor system that has a PSU with 550W of power for the entire system, to see if the GPU works on donor system.
CPU: i5-10400
motherboard: asrock b460m pro4
ram: 2x8 GB patriot 3200 mhz
ssd: mx500 500gb
gpu: new (old but working) gtx 1050ti, was using integrated graphics
PSU: 600w
chassis: some silentium pc case good flow generally
OS: windows 10
Psu is new, 5 months. Wasn't using DDU cuz never had graphics card before. Card is not second had, got it from old PC
