Problem with GTX285's
LordKintaro
8
I have two EVGA GTX 285's in SLI mode.
I've been using the stock fan for the i7 in my build, but today I upgraded to the Xigmatec Dark Knight cooler. I'm not sure if this has anything to do with the GPU's, but I want to provide as much info as possible.
Before I upgraded, my gpu's were working perfectly. I could run Crysis no problem.
After I installed the fan, I pressed the power button on my case, and it didn't turn on. I tried to press the motherboard green button thing on the EVGA x58 mobo, but I might have pushed the clear cmos or something button. When I ran crysis the r_displayinfo showed the logos and menu going at 100fps+ but it looked like it was going at less than 10. I noticed that the gpu memory counter says 335MB instead of 1725MB, which I'm guessing means that there is a problem.
The device manager says I'm at driver version 8.15.11.9038 released on 7/14/2009.
I know the cards aren't dead because I'm using dual monitors and they're working fine albeit slower than before.
Sorry if any of this sounds strangely worded, typed it in a hurry.
neon neophyte
Splendid
BANNED
ESD?
*edit* it was a question. like... were you careful when poking around in your computer? ^^ ESD can have many many varying effects. really depends on what gets zapped and how functional it still is.
LordKintaro
8
Can you provide more info? How would that be the problem? I'm pretty sure I didn't fry it because my monitors are working.
LordKintaro
8
I'm pretty sure I didn't shock my computer. I was nowhere near anything that can create static and I was touching unpainted metal.
LordKintaro
8
Solved by reformatting. I'm lucky that this is a new build and I didn't have anything very important on yet. I think it was a problem with recognizing drivers.
