problem with internet
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
my pc some problem with internet..
i'm having dialup connection..
when i start it, for some time it runs well
after some 10-15 minutes, it slows down and nothing come up..
it has been started from last week, i didn't install any new software or
programme on it.
the windows task manager shows just 0-2% network utilization under
networking tab.
can anybody say what's happening and how to resove it.
thanks in Advance
krunal
First eliminate any spyware.
What You Should Know About Spyware
http://www.microsoft.com/athome/security/spyware/devioussoftware.mspx
CAUTION!!!!! Removing some spyware can damage the Winsock stact. Before
you try to remove spyware using any of these programs , download a copy of
LSP-Fix - a free program to repair damaged Winsock 2 stacks (all Windows
versions)
http://www.cexx.org/lspfix.htm
Winsockfix for W95, W98, ME, NT, 2000, XP
http://www.tacktech.com/pub/winsockfix/WinsockFix.zip
Directions here: http://www.tacktech.com/display.cfm?ttid=257
WinXP:
Get WinSockxpFix
http://www.spychecker.com/program/winsockxpfix.html
How to Reset Internet Protocol (TCP/IP) in Windows XP
http://support.microsoft.com/kb/299357
In WinXP SP2: You can fix Winsock by going to Start | Run and typing
CMD
In the command window type
netsh winsock reset
See
Dealing with Unwanted Malware, Parasites, Toolbars and Search Engines
http://mvps.org/winhelp2002/unwanted.htm
Note that AdAware and SpyBot S & D will each catch some things the other
won't. Also, each needs to be updated with the program's update function
before every use, even when just downloaded. There's also a lot more to do
than just those two programs. CWShredder is also available here:
http://www.intermute.com/products/cwshredder
**Post your HijackThis log to
http://forums.spywareinfo.com/
http://forums.tomcoyote.org/
http://castlecops.com/forum67.html
http://www.wilderssecurity.com/ or the Spyware forum at
http://forum.aumha.org/viewforum.php?f=30 for expert analysis, not here.**
Alternative download pages for Ad-Aware, Spybot, HijackThis and CWShredder
may be found on this page:
http://aumha.org/a/parasite.htm.
See this link for information about malware:
http://arstechnica.com/articles/paedia/malware.ars
If nothing there helps, please post back to this thread.
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com/security/protect/
"~Krunal" <krunal83@gmail.com> wrote in message
news:%238bwLN8XFHA.712@TK2MSFTNGP14.phx.gbl...
> programme on it.
> networking tab.
> thanks in Advance
> krunal
thank you
I have already installed AD Aware Personal & Spybot S & D....,
it has block some 1173 processes as blacklisted and doing search for spyware
once in week using both programs..
also tried winsock reset, but result is same... on the same machine same ISP
in win98, the internet runs well...
what could be problem??
"Frank Saunders, MS-MVP, IE/OE" <franksaunders@mvps.org> wrote in message
news:%23jnKOb9XFHA.3356@TK2MSFTNGP15.phx.gbl...
> versions)
> WinXP:
> Get WinSockxpFix
> CMD
> netsh winsock reset
> See
> do than just those two programs. CWShredder is also available here:
> Protect your PC
>> programme on it.
>> networking tab.
>> thanks in Advance
>> krunal
news:uthuztBYFHA.2348@TK2MSFTNGP14.phx.gbl
> thank you
> spyware once in week using both programs..
> same ISP in win98, the internet runs well...
Did you run CWShredder?
Where did you post your HijackThis log? (Don't post it here.)
Please respond in Newsgroup only. Do not send email
Protect your PC
http://www.microsoft.com./athome/security/protect/default.aspx
http://defendingyourmachine.blogspot.com/
Well Xp tends to reserve some bandwidth to transfer ita file.
This might solve the problem:
Go to RUN---> services.msc
try disabling the service "Background Intelligent Transfer Service"
this might prove helpful, also check which all automatic updates software
are working in backgroung like Live Update (NORTON), windows automatic
update, disable these for dial up connections these really slows down the
system.
Aditya Sinha
