[SOLVED] Problem with laptop battery
enargins
5
I have a 4 year old Dell laptop (Windows 10) which I mostly used on AC power. Even when I used battery power, I used an external battery pack, so as to preserve the internal battery.
A few months ago I used the laptop on battery power, and it was fine. Working normally.
Now I find the following happens:
  • Battery will be at 100% when I start to use it.
  • Will drop to 89%, then slowly to 88%, then 87%, then all of a sudden will go to 6%
  • When I plug the AC back in, it shows charging at 6% with an estimated charge time of 2 hours. Then, a few minutes later, it's fully charged.
Recently I found that the battery meter was not showing in the system tray, nor was it available as an option. So I disabled the battery in Device Manager, and then re-enabled it, and then the battery meter all of a sudden appeared in the system tray.
So I'm wondering if these problems may be software related, rather than just a bad battery, since, as noted, the battery was working fine just a few months ago, and it's hardly been used at all during the life of the laptop.
Thanks!
Most likely needs a new battery.
Being a Dell you can use the Dell Support Assist program, and you may well have a system check within BIOS. I have several Dell systems that can run a self test from the BIOS.
