Problem with my keyboard. Help please.
gustis87
Commendable
Aug 17, 2017
20
Hi, so whenever I click Z + SPACEBAR + Arrow key up + left // Z + SPACEBAR + Arrow key down + left/right it doesn't respond. BUT Whenever i click I click Z + SPACEBAR + Arrow key up + right it does work. Why is this, can i fix it? Ive had this problem on two computers with diffrent keyboards. I am using windows 10 pro as my os right now.
Likely its a n-key rollover issue where the keyboard doesn't support those key presses simultaneously.
Try testing it out here:
http://www.gigahype.com/nkey-rollover-test-page/
If this is something you really want to do look into keyboards that say they have full n-key rollover.
gustis87
Commendable
Aug 17, 2017
20
Do you know any ultra-slim keyboards that have full n-key rollover? And thanks for the answer :)
gustis87
Commendable
Aug 17, 2017
20
It is not ive checked it, on the n-key rollover page those keys dont press at the same time either. But thanks for you concern :)
