Problem with my laptop
My acer laptop won’t turn on. The light on the power button is on but the screen stays black. I can not remove the battery because it’s screwed in. There is nothing wrong with the screen because I checked it out and I cannot identify the problem because it was working fine yesterday. Please help
If the lights are on, then it is getting power and may well be on. Try this...
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
You...
You may also want to try hitting CTRL + SHIFT + WIN + B to try and reset your graphics driver as another possible fix.
