Problem with remote web connection of port changes...
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
hi all,
due to the office policy, i only allow to change the remote desktop port to
80 in order to access, and it works fine with standalone remote desktop
client, however when i try to set up a web connection so that i can access
through web page, the problem came out as the web connection use Active-X
control which default to connect to the remote server using standard RDP
port 3389 and which i trying to prevent, is there any way to change the port
setting on the web connection too? (the tsweb setting)
Thank for any help .....
HGC
Yes you can change the RDP listening port... See these KB articles...
http://support.microsoft.com/default.aspx?scid=kb;EN-US;256986
http://support.microsoft.com/default.aspx?scid=kb;EN-US;322756
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q306759
Reboot the PC after making the registry change...
To change the RDP listening port in the tsweb default.htm file I suggest you use Jeffrey Randow's
(MS-MVP) default.htm file that allows the change to be made dynamically. Simply replace the original
default.htm file with this new on. Make a backup of the original just in case you need to fall back
to the original for some reason...
http://www.remotenetworktechnology.com/LinkClick.aspx?link=revised_rdwc.zip&mid=365
Remember that when your using the web based access method both the IIS port and the RDP port must be
open through your firewall...
http://www.microsoft.com/resources/documentation/Windows/XP/all/reskit/en-us/pree_rem_bgek.asp
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Seyse@@" <dseys@hotmail.com> wrote in message news:OFaZ4%23C2EHA.3092@TK2MSFTNGP10.phx.gbl...
> hi all,
> HGC
Al's links give all the info needed to change ports, but bear in mind that
you are going to need TWO ports--both inbound at the remote location and
outbound from the work location, for this to work. One port for the HTTP
connection, and a second one for the ActiveX control.
You can't use 80 for both of them.
> hi all,
> to
> port
> HGC
Hello there, I forwarded all the ports necessary, changed the port in the
registry and downloaded Jeffrey Randow's version of the default.htm page and
replaced it with what I had and when I try to connect to my PC via RDWC, I
get this error message.... http://home.cogeco.ca/~mash17/ActiveXerror.JPG .
What does this mean and how can I fix this? Thanks,
-Ryan
> > hi all,
> > HGC
It means that IE is setup to not allow ActiveX controls to be installed from the internet. That is
required if you want to use the web based method. Check your security settings...
"Ryan" <Ryan@discussions.microsoft.com> wrote in message
news😀D2D6D35-C917-4D92-B222-172CD0F9AB74@microsoft.com...
> -Ryan
>> original
>> back
>> be
>> > hi all,
>> > HGC
I went into the remote computer's IE security settings and enabled all
ActiveX and scripting and I still get the same error.
> > -Ryan
> >> original
> >> back
> >> be
> >> > hi all,
> >> > HGC
