problem with the cd drive
SuNdus
Commendable
Feb 27, 2016
my laptop is toshiba satellite c50-b1405! I can't figure out how to open the cd drive! helpwould be appreciated! :)
in case it doesnt have a drive can I use an external??
there should be a small button (slightly raised) on the door to the CD drive. Push it, while powered up, and it should open right up. If not, there is a tiny hole that you can insert the end of a paper clip into. Just push it an inch or so into the hole and the door should open enough to pull the rest of the way open.
