My usb disk suddenly works very slowly. Copying operation from system hdd to external usb hdd shows speeds of about 1 MB/s instead of normal 60-110 MB/s depending on the content. I've checked disk with HDDSCAN. What does the error means and what options do I have? P.S. External drive contains collection of movies and I recently started to use it as main drive for torrents.
String # 199.
State:
Model: ST5000LM000-2AN170
Firmware: 0001
Serial: WCJ1FKD1
LBA: 9767541167 (5000 GB)
Report By: HDDSCAN v4.1
Report Date: 07.09.2020 18:48:08
String # 199.
State:
Firmware: 0001
Serial: WCJ1FKD1
Num | Attribute Name | Value | Worst | Raw(hex) | Threshold | |
001 | Raw Read Error Rate | 083 | 064 | 0000000CD1-1455 | 000 | |
003 | Spin Up Time | 096 | 096 | 0000000000-0000 | 000 | |
004 | Start/Stop Count | 099 | 099 | 0000000000-07E6 | 000 | |
005 | Reallocation Sector Count | 100 | 100 | 0000000000-0000 | 000 | |
007 | Seek Error Rate | 077 | 060 | 0000000336-D050 | 000 | |
009 | Power-On Hours Count | 095 | 095 | 19048E0000-1169 | 000 | |
010 | Spin Retry Count | 100 | 100 | 0000000000-0000 | 000 | |
012 | Device Power Cycle Count | 100 | 100 | 0000000000-01A9 | 000 | |
183 | SATA Downshift Error Count | 100 | 100 | 0000000000-0000 | 000 | |
184 | End To End Error Count | 100 | 100 | 0000000000-0000 | 000 | |
187 | Reported Uncorrectable Error | 100 | 100 | 0000000000-0000 | 000 | |
188 | Reported Command Timeouts | 100 | 100 | 0000000000-0000 | 000 | |
189 | High Fly Writes | 100 | 100 | 0000000000-0000 | 000 | |
190 | Airflow Temperature | 073 | 050 | 27 C | 000 | |
190 | Airflow Temperature Minimum | 073 | 050 | 22 C | 000 | |
190 | Airflow Temperature Maximum | 073 | 050 | 27 C | 000 | |
191 | G-sense Rate/Servo tracking | 100 | 100 | 0000000000-0000 | 000 | |
192 | Emergency Retract Count | 001 | 001 | 0000000007-1918 | 000 | |
193 | Load/unload Cycle Count | 001 | 001 | 0000000007-3F02 | 000 | |
194 | HDA Temperature | 027 | 050 | 27 C | 000 | |
194 | HDA Temperature Minimum | 027 | 050 | 17 C | 000 | |
194 | HDA Temperature Maximum | 027 | 050 | 50 C | 000 | |
195 | Error Rate | 083 | 064 | 0000000CD1-1455 | 000 | |
197 | Current Pending Errors Count | 100 | 100 | 0000000000-0000 | 000 | |
198 | Uncorrectable Errors Count | 100 | 100 | 0000000000-0000 | 000 | |
199 | UltraDMA CRC Errors | 200 | 200 | 0000000000-0001 | 000 | |
240 | Heads Flying Hours | 100 | 253 | 0FE20A0000-0331 | 000 | |
241 | Total Host Writes | 100 | 253 | 0000093961-C6A5 | 000 | |
242 | Total Host Reads | 100 | 253 | 0000055978-C84C | 000 | |
254 | G-shock/Free-fall Event Count | 100 | 100 | 0000000000-0000 | 000 |
