Problems in Burning DVDs with Nero
koushik
8
I have an Acer Aspire 4720Z laptop with Windows XP. For the past few weeks my Nero is giving problem. I had Nero 9 when the problem started; whenever I started writing dvd, Nero will burn upto say 3% or 7% and then show error message. So I uninstalled it, used Nero cleaning tool, installed Nero 8 but the problem remained. It began showing message like " Session fixation error G:HL-DT-ST DVDRAM GSA T40N" . Then I changed to Nero 6; but still the same problem. I use various DVD makes available in India like Moserbaer, Writex....earlier also I used to write them having no problem. Another thing I have noted is that even after uninstalling, Nero DriveSpeed, Nero InfoTool, Nero DiscSpeed, Nero ControlCenter stays in Control Panel> Add and Remove Programs dialog box, without mentioning there sizes. Can't remove them. I am attaching the Nero 6 error log........Can anyone help me?
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Nero\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero Version: 6.6.0.8 (Nero Express)
Recorder: <HL-DT-ST DVDRAM GSA-T40N>Version: JP01 - HA 0 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <HL-DT-ST DVDRAM GSA-T40N >Version: JP01 - HA 0 TA 0 - 6.6.0.8
=== Scsi-Device-Map ===
CdRomPeripheral : HL-DT-ST DVDRAM GSA-T40N atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1600BEVT-22ZCT0 atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-T40N G: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2038MB (2087276kB)
Free physical memory: 1399MB (1432680kB)
Memory in use : 31 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.11.2011
ISO compilation
12:17:13 PM #1 Text 0 File Isodoc.cpp, Line 6172
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Continue multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:17:13 PM #2 Text 0 File Reader.cpp, Line 127
Reader running
12:17:13 PM #3 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-T40N running
12:17:13 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
12:17:14 PM #5 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
12:17:17 PM #6 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1804031 (400:53.56, 3523MB)
12:17:17 PM #7 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO (enabled: CD)
12:17:17 PM #8 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: HL-DT-ST DVDRAM GSA-T40N, Media type: DVD-R
Disc Manufacturer: MBI 01 - RG40
Disc Application Code: 64, Disc Physical Code: 193
12:17:17 PM #9 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
12:17:17 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 680608 (680608) = #680608/151:14.58
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 680608 blocks [HL-DT-ST DVDRAM GSA-T40N]
12:17:17 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [HL-DT-ST DVDRAM GSA-T40N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 3 to 3:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1393885184, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
1123424 | lead-in | 0 | 0x41 | 0x00
1123424 | 3 | 0 | 0x41 | 0x00
1123424 | 3 | 1 | 0x41 | 0x00
1804032 | lead-out | 1 | 0x41 | 0x00
12:17:17 PM #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
12:17:18 PM #13 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
12:17:18 PM #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
12:17:18 PM #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11,080 KB/s)
12:17:18 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #1123424
12:17:18 PM #17 Text 0 File DVDR.cpp, Line 2194
Recording mode: Sequential Recording Mode for Multisession
12:17:18 PM #18 Text 0 File Mmc.cpp, Line 21235
Set BUFE: Buffer underrun protection -> ON
12:17:18 PM #19 Text 0 File DVDR.cpp, Line 2340
Start write address at LBA 1123424
DVD high compatibility mode: Yes
12:17:18 PM #20 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 14064F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 140660 h
Start sector number of the next Border-In: 142400 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 14 06 60 00 14 24 00 - 00 00 00 00 00 00 00 00 ...`..$.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
12:17:45 PM #21 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03C44800
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x32 0x4D 0x03 0x0C 0x0C 0x00
12:17:45 PM #22 SCSI -1064 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x05C50000
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x11 0x24 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x2A 0x00 0x00 0x0C 0x21 0x02
12:17:45 PM #23 CDR -1135 File Writer.cpp, Line 311
Write error
HL-DT-ST DVDRAM GSA-T40N\H0 T0
12:17:45 PM #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:17:45 PM #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:17:45 PM #26 Text 0 File DVDR.cpp, Line 2603
EndDAO: Last written address was 1123455
12:17:47 PM #27 Phase 133 File dlgbrnst.cpp, Line 1832
Writing short lead-out
12:17:47 PM #28 SCSI -1176 File Cdrdrv.cpp, Line 1181
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00
0x5B 0x01 0x00 0x0C 0x72 0x04
12:17:47 PM #29 CDR -1176 File WriterStatus.cpp, Line 167
12:17:47 PM #30 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
12:17:47 PM #31 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9200 bytes, created 4/29/2009 1:50:06 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.93.0, size=45648 bytes, created 3/5/2011 1:14:14 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.3311 (xpsp.080212-0003), size=96512 bytes, created 2/12/2008 3:13:12 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
singemagique
196
12
Check your ASPI layer drivers, as this is most likely the problem. Here are good directions and batch files to get the job done. Use killASPI then instASPI. All instructions are on the site. http://radified.com/ASPI/forceaspi.htm
I second the IMGBurn, it is a fantastic program. After using Nero for several years I switched because I could not see spending $50+ for a Nero upgrade. Since, I have never looked back. The only thing I miss from Nero is the audio encoding for making .mp3s, but there are several open source programs for that.
Does your drive read CD/DVDs okay?
koushik
8
Reply from Koushik:
Thanks for suggestions from area51reopened and singemagique. I did killASPI and instASPI as suggested but problem persists. My laptop does not have any problem with reading CD/DVD. Burning stops at 3% and shows error messages like "Could not perform End of Disc- at- once". "Burn process failed at (8X11,080 kB/S)"
koushik
8
Reply from Koushik:
How can I try not using disc at once? I mean, is there any such option in Nero? I have never used it . Can you tell me how to on/off the option? What is basically "disc at once"?
keerthikatanvila
4
01. Try fimware flashing for the dvd writer you have. Try to download the correct file or you'll get the same message.
02. Remove the dvd writer & use contact cleaner to clean the lens.
03. You can also test by writing to good quality re-writable disc whether to make sure whether there is no problem with the set of dvd disc you are writing to.
04. Use nero ultra version 6 & if you can duel boot try doing in a fresh copy of Windows.
**** "Could not perform end of Disc" comes mostly due a firmware, corrupt hardware or software driver issue. I hope above helps****
