Problems loading CD-ROMS
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I've been trying to load SimCity 3000 and Action Replay CDs on my XP but with
both of them I get a error that reads
C:\WINDOWS\SYSTEM32\CONFIG.NT. The system file is not suitable for running
MS-DOS and Microsoft Windows applications. Choose 'close' to terminate the
application.
While SimCity is older, the Action Replay disk is not. Any advice? Thanks!
Seems to be an epidemic lately....
This can be caused by a trojan.
Get rid of the trojan.
Update your antivirus software and run a full system scan.
Copy the autoexec.nt file from C:\Windows\Repair to C:\Windows\System32.
And set Attributes for autoexec.nt to Read-only.
Read-only
[[Specifies whether this file is read-only, which means that it cannot be
changed or accidentally deleted.]]
1. Right click the file.
2. Properties.
3. Select: ? Read-only.
4. Click: Apply.
5. Click: OK.
16-bit MS-DOS Subsystem error while installing or running a DOS application
http://windowsxp.mvps.org/16bit.htm
MS-DOS or 16-bit Windows-based program Error Message
http://www.kellys-korner-xp.com/xp_m.htm#16bit
Error message when you install or start an MS-DOS or 16-bit Windows-based
program
http://support.microsoft.com/default.aspx?scid=kb;en-us;324767
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:B8E54AE5-3733-4FCA-9118-47BBF2DE5890@microsoft.com,
SouthernIndiana <SouthernIndiana@discussions.microsoft.com> hunted and
pecked:
> but with both of them I get a error that reads
> running MS-DOS and Microsoft Windows applications. Choose 'close' to
> terminate the application.
> Thanks!
