G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have a Gateway 1800 that i bought new a few years ago. For quite a
while I was running a CD-rw and a DVD rom both in addition to the
3.5 floppy and had no problems. A few weeks ago the dvd rom started
giving me problems as it would no longer play dvd s or cds. I
figured the unit had just gone out so I boutht a new one and installed
itl. I still have the same problem. When I put a cd in the unitm
the light on the dvd rom stats flashing on and off like normat but the
cd does not autostart. When I go into my computer and click on that
particular drive, I get an illegal access code errir nessage, If I
mess around and click this and that button, finally a software type of
cd will play.
I checked the jumper settings and one is set to master and the other
is set to slave as it is suppose to be. I am running Windows xp home.
Help!!
cd will play.
Help!!
