Question Problems with .Net Framework
Enrok M
76
Hello, every time i restart or turn on my computer, i am greeted with this error. It has happened before, i've been playing few games, and every time i needed to launch the game, computer were asking me to install .Net Framework or something like that, one time you click install and the game runs, after a while you launch the game again, same requirement but then you hit Uninstall and game launches again, and so on every time you want to play a game, it happend with 2 games only. One of them was postal 4 and i cannot remember the other one. Its weird and i have no idea what is that. Thank you for your answers!
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
** Exception Text **
System.IO.FileNotFoundException: Could not load file or assembly 'RSy3_AudioAppStreamsWrapper.dll' or one of its dependencies. The specified module could not be found.
File name: 'RSy3_AudioAppStreamsWrapper.dll'
at Synapse3.UserInteractive.ApplicationStreamsEventHandler..ctor(IAccountsClient accountEvent, IApplicationStreamsEvent appStreamsEvent)
at Synapse3.UserInteractive.HiddenForm.<HiddenForm_Load>d__21.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_0(Object state)
** Loaded Assemblies **
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4614.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Razer Synapse Service Process
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Razer/Synapse3/UserProcess/Razer%20Synapse%20Service%20Process.exe
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System
Win32 Version: 4.8.4605.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Windows.Forms
Win32 Version: 4.8.4550.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
NLog
Win32 Version: 4.2.3.1371
CodeBase: file:///C:/Program%20Files%20(x86)/Razer/Synapse3/UserProcess/NLog.DLL
System.ServiceModel
Win32 Version: 4.8.4536.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Data
Win32 Version: 4.8.4584.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Common.DeviceCallbacks
CodeBase: file:///C:/Program%20Files%20(x86)/Razer/Synapse3/UserProcess/Common.DeviceCallbacks.DLL
** JIT Debugging **
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
View: https://imgur.com/a/nJ8wnP2
error log says file is missing, thats from razer synapse, reinstall that one
if razer synapse will still throw this error, then reinstall .net framework
that is in windows features uncheck .net framework 4.xx to uninstall it when you press apply button, then checkmark it back to install it back
if that error is only informative and running apps still works, than you can hide it here
Thank you for your answers! So i tried reinstalling Razer Synapse and .Net Framework. Everything is still same. First i tried reinstalling razer synapse, after restarting pc i had no error, but as soon as i installed it back, error came out again after another restart. Then i uninstalled .Net Framework, restarted my pc and got same error, then i installed it back by checking the boxes in Windows Features and restarted my pc again, aaaand nothing 😢 same error and my razer software doesnt launches (It didnt launched before as well, forgot to mention)
check the os update they had a net framework update last week .
Thank you, i probably had updated my system recently. I am running on very specific version of windows. LTSC. Maybe that could have some problems in common?
Edition Windows 10 Enterprise LTSC
Version 21H2
Installed on ‎2022-‎08-‎30
OS build 19044.2604
Experience Windows Feature Experience Pack 120.2212.4190.0
dont know if there is compatibility issue with razer synapse and your windows version, you could contact razer support
Will try to, all apart from that, how do i fix this issue with .net framework? Becouse its not a first time happening, something is wrong, I did all the steps. Tried reinstalling both drivers and framework
.... And a legal copy of LTSC edition for private user would be probably impossible to get
Correct.
Either obtain and install a LEGAL copy of Windows or receive no more support here. We take piracy seriously.
You can obtain such a legal copy here: https://www.microsoft.com/en-us/software-download/windows10
It will run just fine without entering a license (within certain limitations). If you need 100% fully functional then you will have to purchase a proper license code.
