Archived from groups: microsoft.public.games (
More info?)
Hi Peter,
"Peter F" <PeterF@discussions.microsoft.com> wrote in message news:8BC6E475-9077-4295-8562-F78E195FD6C8@microsoft.com...
| Hi all,
| Hope you can help.
| While playing 'The sims' e.g Delux edition, Superstar, after 5 minutes of
| playing the game it closes itself down. Theres no icon on the taskbar to show
| that it is still running. This is getting to be a bit of a problem.
| Computer Spec: Pentium 4 3.04ghz.
| 1.0g Ram.
| Windows XP Home Edition.
| Service Pack 2 recently installed.
| Nvidia geForce FX5500 Graphics card.
| Any information would be greatley recived.
| Thanks.
| Peter
Hardware issues can cause freezing, black screens and other
errors. Also, your drivers should always be kept up to date.
Try the following steps one at a time to try and resolve the issue.
I hope this helps. Please post back if you have any questions!
1. Update DirectX and your Chipset, Sound, &Video Drivers:
For all Video / DirectX / Game and Hardware Issues, I have a
Checklist of Solutions at:
http://NibblesNbitsVideo.tk
2. Dust your fans, vents and components using a 1/4" paintbrush
and a hose vacuum. Use compressed air for hard to reach places.
Set a housefan to blow cold air into your case to expose an over-
heating issue.. If it works add more fans or replace defective ones.
Use this Motherboard Monitor Utility:
http://mbm.livewiredev.com
3. A faulty power supply can cause STOP errors, random reboots,
and black screen lockups. One way to test for that is to check the
wattage sticker on your power supply and then calculate your need
http://www.jscustompcs.com/power_supply/ (Min. 350 for gaming)
4. Test your RAM using:
http://oca.microsoft.com/en/windiag.asp
Cheers, Windows XP MVP Shell / User
Jimmy S.
http://mvp.support.microsoft.com
Game FAQs:
;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite:
http://nibblesnbits.tk or Call / Contact
MS Support at:
http://support.microsoft.com/default.aspx?scid=sz;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
