Problems
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Lots of problems here. Appreciate some answers to the following:
When you apply the thermal paste just how much do you put on? Do you just
put a film over the square that sticks out of the processor? Or do you put a
big square over the back of the heatsink?
At just what temperature is an Athlon XP 2000 Palomino core supposed to run
at? Is 66C too high (its a very warm day here today).
Why is the CPU usage permanently 100%? Running 256MB of PC133 SDRAM on a MSI
KM2M combo. Windows XP Pro.
Cheers people.
a
Put a dab on the square on the processor. Take a piece of saran wrap and
place it over your finger. Now rub it smoothly over the processor contact
area. A very small amount only is needed - enough to cover the square.
This is of course after you've cleaned both the processor and the heatsink
with some rubbing alcohol and a lint-free cloth.
run
Sounds high, but I don't know.
MSI
100%? Where do you see that number?
For example, if you look in the proccesses panel, you might see "idle" and
98 or 99%, which is normal. If not, look there (press ctr-alt-del and
select the process tab) and see just what is using your cpu.
Put a small dab on the core (the raised center part).
Scrape it off with the edge of a credit card.
You should be left with an extremely thin film of compound that covers
just the core. Think "less is more", since excess compound will
inhibit thermal transfer.
66C is on the warm end of things. If it gets much beyond 70C and/or
you experience stability problems you may want to consider better cooling.
You tell me. Look at the task manager and see for yourself what's
using the CPU time.
-WD
Latest posts
