Processor Help
chases-comp
4
Hey guys, I was hoping someone could help me with something. I'm wanting to buy a gaming laptop that's very portable but also very capable. The one I have picked out is here: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=416904&CatId=4938
I know its obviously not the best of the best of gaming laptops, but from the reviews I've read it's very capable. It seems the best, and is also my favorite for my budget. What worries me most is the processor. 2.0GHz i7. I know the new 3rd generation i7's are out, and I was wondering if this one will be obsolete soon? I want a computer that I can hang on to for a couple years and that will still be considered a capable gaming computer. Any thoughts or suggestions would be greatly appreciated. Thanks guys :)
Everything is obsolete as soon as something new comes out. The third gen i7s will be obsolete in a few months so it really doesn't matter what you buy if you want to keep it for a few years.
That computer I would not recommend as a gaming computer. The 555m isn't very good and its the most important part of a gaming system.
Alienware is over priced as always either way.
Well was certain that the ipg had to be turned off to use the graphics card. Not "dual graphics" with the Intel ipgs.
But other than that it seems fine. I don't think Ivy bridge is much better other than lower power-usage, which is good for batteries.
edit: ninja'd I don't know about the 555m btw or how good it is. (never heard of it)
You always go to the Alien ware website and look there for new ones.
The problem with the new ones is that they're out of budget 🙁
Btw I appreciate the input guys.
And to clarify esrever, I don't always need or expect to play games on the highest graphics setting.
the 555m is about 10% better than the best trinity APU. Trinity is really good if you want decent gaming performance for cheap.
Latest posts
