After a lot of thinking I decided to scrap my idea of having two systems in a single case and instead go for something a little more pratical and more cost efficient. This is Project Red Pill. It will be my everyday use pc, HTPC, high end gaming rig, VM and rendering system. I MAY even do some benching or something but I really haven't put much thought into that as of yet. I am currently running a single 1080p monitor but will either be upgrading to a 1440p monitor and adding a second GPU or, keeping a single GPU and my monitor until the 8000 series is released then I can invest in an 8000 series card and a new monitor + second card later on. So any opinions on that would be great. Keep my card and monitor until the next series or just invest now and upgrade once either the NEXT series comes out or the prices drop on the 8000 series.
This is going to be kind of interesting in that it will run 3 closed loops over a custom loop. An H100i for the 3930K in push/pull, and a (two) Red Modded Antec 920(s) for one or two GPU's. This is both cheaper, easier on me as I have never built a custom loop before and it will allow me to try out a simple mod to cool my GPU(s) called, The Red Mod. Once the 8000 series is released and waterblocks start coming out I can more than likely replace all my closed loop coolers with a custom loop. For now though, this is the route I have chosen to take.
So any opinions, suggestions and/or comments are all welcome. As well as if you have any questions about my component list or anything I did not explain clearly enough in my OP.
Forgot to add the budget for the build. That would be around $3000, which this is about $2991.09.
OS: Windows 7 Home Premium 64-Bit OEM
Case: AZZA Genesis 9000B
MoBo: ASRock X79 Extreme11
RAM: Patriot Viper 3 16GB (4 x 4GB) 2133
CPU: Intel Core i7-3930K
CPU Cooler: Corsair H100i + 2x SP120 High Performance Edition
GPU: PowerColor AMD Radeon HD 7970 PCS+
GPU Cooler: Antec KUHLER H2O 920 *Red Mod
SSD: Samsung 840 Series 250GB
HDD: Seagate Baracudda 3TB 7200RPM
PSU: SeaSonic X Series 1050W
ODD: ASUS DVD Burner OEM
*The Red Mod is basically using a CPU cooler to cool a GPU using a custom made mounting bracket or zip ties to secure the waterblock. Exactly the same as "The Mod" for Nvidia cards.
