Proper MoBo and PSU for my rig
Toa
48
So I am building a computer, it will be run by Windows 8.1 and the computer specs I am leaning toward are:
CPU: Intel i7 4770k
GPU: GTX 780
HDD: Western Digital 1TB 7200 RPM 64MB SATA 6.0Gb/s internal Hard Drive
RAM: Corsair Vengeance Red 16GB DDR3 1600 MHz Desktop Memory
SSD: Samsung 840 EVO 250GB
Now if you haven't noticed by now, I didn't list a MoBo or a PSU, both of which I have not chosen yet. For my MoBo I do not need all the bells and whistles, just something that performs well, and can OC well. As for the PSU, I would just like to have one that can perform well w/o overheating and can provide enough wattage for my gaming needs. I am already going over my budget so I don't want anything to painful on the wallet. Do note that this is my first rig, that may not change much but I thought I should have said that. And I would appreciate anyone noting problems with my rig, or suggestions for it.
i have exactly same specs for my computer and my mobo is Asus Maximus VI Hero
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131989
and my psu is seasonic x850
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151102
these might be out of your budget but they are very good components or you can go with any of these motherboards and psus
Motherboards:
http://pcpartpicker.com/part/asrock-motherboard-z87extreme6
http://pcpartpicker.com/part/gigabyte-motherboard-gaz87xud4h
http://pcpartpicker.com/part/asus-motherboard-z87pro
PSUs:
http://pcpartpicker.com/part/seasonic-power-supply-ss750km3
http://pcpartpicker.com/part/xfx-power-supply-p1750bbefx
http://pcpartpicker.com/part/corsair-power-supply-ax760
Motherboards:
PSUs:
