ps4 on 1600x900 if not then 1080 on 1600x900 monitor possible ?
saim072
27
Hello,
I am buying a ps4 but i have a 1600x900 but i am afraid that it doesn't support 1600x900 i have samsung 22" led with only dvi and vga.
I will use hdmi to vga converter with 1080 support.
So question is that ps4 works on 1600x900 monitor.
Other one is if it can't be run on 1600x900.
Can i use 720 or 1080 on my led.
Hello saim072
You'll be able to hook up your Playstation 4 to your 1600x900 monitor with no problems at all!
However, that means that the maximum resolution will only be 900p (1600x900) on your Playstation 4 no matter what. You won't be able to run your Playstation 4 at 1080p on a 900p monitor. Overclocking a resolution on a monitor isn't possible... yet.
All your PS4 games and everything on the...
Hello saim072
All your PS4 games and everything on the PS4 will run fine at 900p with no worries.
Hope this helped! :)
EDIT: If you upgrade to a 1080p monitor in the future than your Playstation 4 will be able to run at 1080p.
I have seen their are only
480
720
1080i
1080p
Resolutions in ps4 but at same time their is also a AUTOMATIC RESOLUTION.
I am not very rich i am just managing to buy ps4 but i can't afford a new lcd.
Will it wil be okay to play ps4 on 900p
Please answer me in details because i don't wont that after purchasing a 40,000 gadget i can't even play it.
Thanks
As I said above...
The Playstation 4 will recognize the highest resolution possible on the monitor your using and set it to that resolution which in this case is 900p (1440x900)
Hope this helped!
