Ps4 power supply blows will it affect the motherboard
coty__13
Commendable
May 2, 2016
12
Hi my ps4 power supply blew a few weeks ago so i was wondering if it will affect the mother board in any way? I know the main reason was the power supply but i want to make sure it didn't hurt the mother board as well.. so please tell me its ok
Well the power supply unit is part of the system.
I mean part of the PS4.
It should be built on a separate segregated board though.
Where the output from it connects to the main circuit board of the PS4.
So with that in mind it should have protection built in for any current spikes, or short circuit protection.
Or any over current protection circuits built into it.
The tell tale sign would be to look where the power that exits the power supply circuit boar to the main PS4 board.
would be any melting or blackening around the connection or plug points.
And using your nose to detect any burning or acrid smells from the points mentioned.
Plus a good visual inspection.
It depends how good sony designed the power board to be honest.
But...
I know that.. im order the power supply tomorrow but im trying to see if anyone ever had any experience or not..
But I would say since its a company known for producing quality products.
The Ps4 will probably work with a new supply board fitted in it.
Just one thing Coty what caused the other board to fail or blow.
Liquid or anything like it, or did it just pop on it`s own ?
It was some kind of ant that got into it and touched one of the circuits and blew it to the point that it melt the plastic.. i didn't hear anything because i had my headsets on.. but if you say its protected then i fell so much better lol thank you for your answer.. it helps me a lot.. i hate bugs that like to get into things
