Friend, you should have the fan down, that will provide better cooling for both your PSU and system
The case was designed so that you have the fan this way. Othewise, it would not have the vent and the PSU would mount on top, as have been in older cases.
By having the PSU dragging fresh air from the bottom, it gets a cooler air than if it was dragging air from inside the case, wich would get to it alredy heated. In addition, air inside the case gets 100% focused on refreshing system components.
