[SOLVED] PSU Cable Recommendations For MSI RTX 3080
Sep 24, 2020
Hello, I am thinking of upgrading my graphics card to the new 3080 and I need to know if my PSU will support the 8+8+8 pin on the graphics card. I have lost my cables for my PSU so I am going to buy new ones.
RIG:
Ryzen 7 2700x
Asrock B450m Steel Legend
32gb Trident Z 3600
GPU Upgrade: GeForce RTX™ 3080 GAMING X TRIO 10G
Corsair CX650M
Thank you for your help.
RIG:
Ryzen 7 2700x
32gb Trident Z 3600
Corsair CX650M
You'll be pushing your lower budget power supply pretty hard with the GPU upgrade. You may want to consider upgrading the PSU to a higher quality model with more power.
- Corsair sells the replacement cables you need for PCIe...
RIG:
Ryzen 7 2700x
32gb Trident Z 3600
Corsair CX650M
https://www.corsair.com/us/en/Categ.../Type-3-Sleeved-Black-PCIe-Cable/p/CP-8920111
- MSI recommends a 750 watt PSU for that card and you need to verify it will fit whatever case you're using. The card length is 323mm.
https://us.msi.com/Graphics-card/GeForce-RTX-3080-GAMING-X-TRIO-10G/Specification
- Testing shows whole system power draw can exceed 500 watts. A little more headroom for the PSU might be a good idea but that's your call.
https://www.pcworld.com/article/3575104/msi-geforce-rtx-3080-gaming-x-trio-review.html?page=4#toc-5
Reactions: Vic 40
https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Power-Supplies/Type-3-Sleeved-Black-PCIe-Cable/p/CP-8920111
Thank you
