Hello
I've been building my pc but just hit a snag with the power supply cables and gpu.
the GPU has a 8pin connection(female) and a 6pin slot
I've been provided with these cables, but the cables on my old build were slightly different.
I'm not familiar with the lingo for power supplies so I'll just type it out as I see them:
OLD PSU:
The old PSU/build was semi modular, so this setting below worked fine:
8 pin(already attached to psu)with a 6+2 cable (the last 2 pins on the 6+2 were not in use)
NEW PSU:
However, the new EVGA 720W G3 psu has these cables:
8pin (6+2)----- x2 cables(8pin on each cable)
8pin(6+2) with a shorter cable with another 8pin (6+2)----x2 cables (16 pin on each cablel)
Now considering my old build was using 2 separate cables, is it fine to use 2 separate cables in this case or alright to use the (6+2)+(6+2 with the 2pin hanging out)?
(I'm also restarting my computer, so I'll reply back in about 5-10mins)
OLD PSU:
NEW PSU:
