So, I recently got some parts in and pretty much changed everything save my GPU & Case. Plugged everything in, got it working, but decided realized my 16 core CPU would probably need the extra 8? 6? pin plug in, so I did that and decided to mess with cable management a bit. I got almost everything plugged back in, however I had issues with 2 things:
The 2 CPU plug ins were very tight due to my top mounted radiator, so I couldn't really tell if I was slotting the pins in all the way. I applied a ton of pressure multiple times, but my fingers are so raw I gave up after a while without hearing a click.
My GPU connectors are I think 8 pin? Whatever the standard is, and I require two for my NVIDIA GeForce GTX 1080 TI. The pins I have are 6 with an extra 2 pin attached. The first cable plugged in fine, and so did the 2 pin; but the 2nd cable's 2 pin isn't fully seated. It seems to be conflicting a bit with the 6 pin / not slotting into each other properly, so there's a bit of a gap between it & the GPU.
I got both plugged in as much as possible and cut the PC on, and everything powered up fine and seems to be functioning as intended. I'm just a bit worried I might * something up in the long run with things not clipped entirely. Reckon this is OK, or should I give it another go and try pushing until I hear clicks
