PSU dual 4 eps pin don't fit to 8 pin MOBO
deverth
12
Hi, I've got a question. Lastly I bought new motherboard- msi z370 gaming plus and now have a problem with connecting dual 4pin to CPU 8pin eps slot via8pin extension cord.
Seems that extension cable fit perfectly to the cpu slot on motherboard but both 4pins are identical/simetrical (photo).
I can force both 4pins to fit (all yellows to yellows, blacks to blacks) but I'm pretty sure if that would be ok... :d
The PSU is forton fsp500
I'm really confused right now. What should I do?
Hope for your help! ^^
Latest posts
