[SOLVED] PSU Fan is making painfully loud noise
SawmMawia
Great
Jan 17, 2021
180
8
85
When i turn on my pc,the psu fan starts to spin and makes a painfully loud to hear sound,and if i like smash the table,it goes normal for a while and gets loud again.
Help
if it is actually the PSU fan and "knocking it" resolves the issue;
if under warranty, contact the manufacturer and have them replace it.
if not under warranty, you can try pulling out the fan and oiling the bearings.
