Hello there.
I am using an rtx 3080 and 5900x with an Cougar GEX 850W GOLD 80+, Cooler Master 511 rgb case.
The issue is the following, when playing games demanding ones especially the PSU makes a loud noise like a jet engine for a sec or two and then stops when an stable temperature is made. I m guessing that it's the fan probably?
For example in the game I play the stable temperature of the GPU is around 70 degrees, however when I pause the game or go to the menu it can go down to 43 degrees, and when I resume the game the ramp sound kicks in a few times and then stops.
My question is this a normal behavior of this PSU or for all PSU's of this type?
Below is the sound recorded:
https://drive.google.com/file/d/1Q5OXMg0mVVp4c520uHzhMh1_dff8PdCT/view?usp=sharing - Please skip to 00:15 and 00:32 - the fans that can be heard from the start are the GPU ones, the ramp up and down is coming from the PSU
Thank you.
Thank you.
