PSU into Motherboard Cable
Aug 29, 2018
13
There's a PCI-E cable that is coming out of my PSU. It's a EVGA 650 BQ. The cable is non detachable and I'm not sure where the molex goes.
Do you have your PC Specs or does that answer your question ? I guess your either using a Graphics card that isn't potent enough to require additional power (Cards can get up to 75 Watts from the Motherboard without direct power) or not using one at all :)
I thought the VGA cable was for the GPU? I'm using a Ryzen 5 with integrated graphics. Right now I'm waiting for a male 4 ping plug to ship to me so I can plug it in the PERIF spot on my PSU and hook up my fans and RGB lights for the case. After that I think I did everything else.
My Specs as Follows:
Thermaltake Versa C21 RGB Tower Case
Ryzen 5 2400G Processor with Integrated Vega 11 Graphics
MSI B450 Gaming Plus Motherboard
1 TB SATA 7200 RPM Western Digital Hard Drive
LITE-ON 128GB SSD
XPG 256GB M.2 SSD
Panasonic DVD Writer/Reader
Asia Horse RGB Fans w/Controller
Patriot Viper 16GB DDR4 Memory Kit 2400MHZ
650 is the standard nowadays in my opinion. I had a Lenovo Erazer X315 before with the AMD FX 770k CPU and Radeon R9 360 GPU. With the new Radeon Vega 11 APU I can overclock it and get 60 FPS playing BF1. I brought the drives and the DVD burner from the old machine too. I plan on duplicating everything on my SSD and putting it on the M.2 drive for quicker boots and protection. I also plan on putting my 2 games on there as well. It should fit. Everything else will go on the SATA drive until I plan to buy another because that's prolly gonna go soon as well. Lenovo had a diagnostic program for the hardware. Hopefully I can find another one.
Eventually I'll probably buy a GPU. By the time I burn out the APU from overclocking I can probably buy an even newer Ryzen processor and the Geforce 1070 cards will be selling for a hundred bucks. I've got it all planned out. Battlefield 5 looks like garbage anyways so I'm gonna stick to playing BF4 and BF1. I only paid $10 for the latter so I'll factor that into my savings. I was just on the Lenovo website and their new "Legion" series desktops use the same drives I have. They charge thru the roof for RGB lights. It's ridiculous what you can do nowadays by putting a couple of sale items together. This isn't counting mail-in-rebates.
I bought the right PSU.
But you really didin't. First, 650W might be what Nvidia suggests for a PSU, but they say that to cover for the garbage PSUs that exist out there. Second issue is the BQ is a basic, 80+ Bronze unit. It's not a fancy or good unit by any means. Final is price. I really hope you didn't spend this much.
https://www.newegg.com/Product/Product.aspx?Item=N82E16817438084
$75 + 6 more in shipping is just too much for a bronze unit.
https://www.newegg.com/Product/Product.aspx?item=N82E16817151202
Here is the Seasonic Focus plus for $80 out the door. That's the 650W model, the 550 is even less. Both of the Seasonics are top notch and 80+ gold.
I'm glad you have a good PSU and I don't mean to be rude. But when I hear people say they did good when they really didn't... I'm sorry, I'll move on now.
