PSU Makes random Noise Sounds !! HELP
May 19, 2018
the sound is actually loud and it's very annoying
i can hear this while the PC is TURNED OFF !
https://www.youtube.com/watch?v=fOIBNVwtcZo
noise sounds : 0:00 0:23 0:26
due to my bad camera and mic you might not hear the noise so please ENABLE the Loudness Equalization
Open up Sound in the Control Panel (under "Hardware and Sound"). Then highlight your speakers or headphones, click Properties, and select the Enhancements tab. Check "Loudness Equalization" and hit Apply to turn this on
my power supply : www.green-case.com/products/power/GP600A-HP.html
Spec : 1060 GTX
Ram Crucial Ballistix Tactical 16GB 8GBx2 3000Mhz
MSI B250 GAMING PRO
Intel® Core™ i5-7500
