that is a good one it is 80 plus and it is antec very reliable
the thing with PSUs is you don't want to skip on cost even if your PSU is expensive it will make or break oyur computer
a bad PSu can cause your system to be unstable and sometimes might cause problems to other components such as frying the cpu or shorting the mobo and the worst would be damage to a HDD
so good brand are: OCZ, Corsair, Silverstone, Seasonic, PC&PC, Antec
they are equally reliable and in the end it comes down to hjow much power you need and what brand you prefer
the PSU you linked is good, now just see if it meets the power requirements of your computer
