since this is the only place i can rant over recommendations, as much as i disagree with it.
a couple rants, which might've been mentioned before (by me and others)
<rant>
We didn't get any OCP results because our unit died during the OPP test, meaning either that this particular sample had a problem or OPP is set very high. Note that we conduct these tests at normal ambient temperatures, below 30°C.
https://www.tomshardware.com/reviews/evga-supernova-1000-g3-psu,4941-6.html
why would you recommend a g3 on that alone? then something comes added with that
OTP is set very high in our opinion, since we had to apply a huge thermal load on the secondary side to trigger it. The bulk cap's external casing nearly melted during our OTP evaluation.
https://www.tomshardware.com/reviews/evga-supernova-850-g3-psu,4930-6.html
you disqualify the s12iii based off that it's partly produced by RSY. then i recommend you write off the complete low end of Seasonic, as they're also partly produced at RSY (s12ii, m12ii, m12ii evo), and i don't know for what part, but from what i've heard SuperFlower also does part of it's production at RSY.
what's exactly wrong with FSP and EVGA? FSP has shown to make some amazing units for Listan (Be Quiet), even if those were mostly custom designs by bq themselves. heck, even evga themselves now have one of the better SFX units on hand with the GM. the g5 1000w has ripple issues, but there's nothing directly wrong with the lower wattage units, as they're based off (or at least close to my eye) to be quiet's power zone design, which was for a budget oriented unit just fine. maybe g5 wasn't meant to be a followup to the g2/g3 line.
speaking about g3, if you like it so much, why not start recommending the Leadex III? this is pretty much the fixed design version of the G3, even if it still is set high for my likings and the 750w has shown some ripple issues as well
CX/CXM green is internally the same as the current CXM 2015/17 on 750w+
what's wrong with CWT GPU/GPS?
does it have to be from a company that has been providing stuff for years so you don't give new players working together with the usual big OEMS like CWT, GW, FSP and so on a chance?
Single rail<Multirail, especially above 650w
realhardtechx hasn't been updating for a long time now
Focus FX has huge ripple issues, start shifting people over to GX/GM if it turns out okay
CX and CXM are not the same, and CX should always be chosen above it for the topology alone
AXi can't be beaten by prime, heck... i'd currently take something Delta GM based over it
what is selective about BQ if only 2 units are somewhat problematic? (pure power 11 300/350w), what makes it have a disadvantage over the others? because it's German?
Fortron/source isn't the only company that is part of FSP
group
Cooler master has a unit that beats the crap out of most units you daily mention here, being the V platinum 2019, based off delta's GM platform, with that masterwatt, MWE v2 (if reviews turn out okay), Masterwatt Maker, Masterwatt maker MIJ and Masterwatt are in their class not horrible options, thermaltake does have some decent options including Toughpower Grand Gold, Toughpower Grand Platinum, iRGB Plus, DPS Gold and GF1. masterwatt lite just dropped that far because they had no UVP, and that's the thing i've been warning for that can happen on S12ii/M12ii and many other group regs with no or partly UVP.
I thought to have seen an actual decent chieftec a while back, but i don't recall the model
HEC/compubase/cougar is stupid to write off, as they are a major oem which can make decent units
same with High Power/Sifra
Xilence is part of the same company as Be Quiet, and has as decent units the performance X and A+
Raidmax once came close, but forgot otp on their 1200w 80+ titanium unit
</rant>
thanks for reading
