Using statistics to predict mortality rates, failure rates, etc. is totally different than predicting which direction technology is going to move in the future...
what i meant is that it doesn't need to be released , not invented , when everything is still on paper you can use probability theory and statistical inference to predict the future performance of that technology , and what are the possible failures and their ultimate consequences , and decide which are credible scenarios and which aren't , and accordingly alter the design in a risk based manner , before procurement or production happens and this is how most of the safe design and protective features are determined
you can find aris credentials here
https://landing.coolermaster.com/pages/cybenetics/
Honestly not the worst idea ever. I think you would have pushback from the PSU manufacturers. Not much competition in making a single voltage PSU, whoever makes the most efficient or cost effective components would the winner.
for the PSU manufacturers its easy and cheaper , motherboard manufacturers and end users are the problem here , from the motherboard side in addition to increased costs and point of failures , it's currently very crowded with no space left at all around the edges to accomodate for additional power connectors so they can be routed nicely behind the tray and allow for cable management , and the end users are all going toward rgb and tg panels which means any additional cables showing are not that welcomed ( unless the make them RGB power cables
It's VERY unlikely that motherboard manufacturers are going to want to have to shoulder the additional requirements themselves, or the cost.
I agree and even if motherboard manufacturers did they will not find a buyer for it , but i just see it as trend that has been going for a long time in some major prebuilt system manufacturers like HP and Dell so intel decided to standardise that practice which is a good thing , but i was surprised when fsp released a consumer product .
And AMD is sweeping the rug from under the feet of intel as you mentioned may weaken their ability to force that standard
Ah, Eximo, 😉 it's not the voltage. Anything more than 88mA and you loose the ability to 'let go' of DC voltage, and 500mA will produce fibrillation in 0.2 seconds. Both the 5v and especially the 3.3v rails deal with amperages well in excess of those, and if those rails were open air on a pcb, well that's a disaster in the making with all the caps used etc. The box the psu guts come in serves a higher purpose than just a place to park a sticker.
But its Voltage that determines How many AMPS will be pushed into your body after dealing with both your Skin's Capacitance (in case of DC) and Resistance and cause the adverse effects you mentioned
DC at 12V wont be able to push that many amps through your skin capacitance and resistance
