Few things to point out since people still seem to get Seasonic lineups wrong.
It seems to be a far better unit than a S12ii/M12ii.
M12II is comparable only to S12II 80+ White PSUs since M12II PSUs are also 80+ White and produced in the same time period.
The actual S12II talked about is S12II 80+ Bronze and it's M-series equliveant is M12II EVO 80+ Bronze.
Or to put it short:
S12II 80+ White and M12II 80+ White are equal.
S12II 80+ Bronze and M12II EVO 80+ Bronze are equal (almost, see below).
But it's about a decade old, group regulated (no dc-dc) and lacks a lot of modern protections.
Another thing to point out is that not all S12II / M12II EVO PSUs are group regulated. M12II-750 EVO and M12II-850 EVO are actually DC-DC regulated.
Also, just because PSU is group regulated doesn't instantly mean it's bad. Sure, the group regulation is older technology compared to the DC-DC but there are newer DC-DC PSUs out there that actually are much worse than the pinnacle of group regulation technology seen in S12II/ M12II EVO PSUs.
As far as protections go, those protections that were required back then, Seasonic also added to their PSUs.
It's like saying '55 Bel Air is a bad car since it doesn't have airbags and seat belts. While in reality, car itself isn't bad at all but at that time, those protections weren't required.
Also, those "a lot" of protections S12II / M12II EVO group regulated PSUs are missing are actually only two: OCP and OTP.
M12II-750 EVO and M12II-850 EVO do have all 6 protections present: OPP, OVP, UVP, OCP, SCP, OTP.
With that, i won't say that they miss "a lot" of protections.
I believe due to its lack of uvp protection and being group regulated, it can have voltages go out of spec in a modern PC where the 12v rail is loaded far more than any other rail.
Well, if you load group regulated PSU in a way they aren't designed to handle, you'll get out of spec voltages. However, in his S12II-520 review, OklahomaWolf had this to say:
While the first CL test did see the 12V climb out of spec, the second CL test did not see a corresponding out of spec increase on the 5V. It gets close, but does not go out of spec. This unit is remarkably well behaved for a group design.
This is what I like to see - not many rigs these days will present a load like the one from test CL1. Such loads went out with the Pentium III and a few select Socket A motherboards. CL2, on the other hand, is possible on modern rigs, and I love that I did not see out of spec numbers there. Well done, Seasonic.
On to the voltages in the five progressive tests. Again, the S12 II looks to impress, with abnormally stable (for group regulation) readings. 5V is within 1% regulation, and the other two voltages come in just outside of 1%. Very nice indeed.
Review:
https://web.archive.org/web/2015010...odules.php?name=NDReviews&file=print&reid=185
