Psu watt quality
JOHN PLAYER
40
hey guys..
i have bought gtx 1080 gaming z sli with i7 6700k
i have already a cooler master silent pro 850 watt
is that psu enough for my sli ready graphics or i need another like corsair or seasonic
give some suggest
or the link I posted 😉 solid advice though
Hi,
If we talking about watt it should be enough but in term of quality if it is not at least 80+ certified and bronze or higher then it is a bad one. Keep using it until it dies or start to act in a bad way but if you want to get a good one also since blackfriday is close for deals then get either:
Seasonic / Corsiar / EVGA: 80+ certified bronze/gold/platinum/titanium semi or full modular.
For me I have EVGA Platinum for almost a year and it is working perfectly.
Regards,
Its 80+silver i am using almost a year but i am confuse because some its not good for your sli
Hi,
Which one is your PSU:
Cooler Master Silent Pro M - 850W
Cooler Master Silent Pro Hybrid 850W
Cooler Master Silent Pro M2 850W
Regards,
Bad advice. When a PSU dies, it can fry some other components with it. That's why it's recommended to buy a good quality PSU. It will keep your other components safe.
Cooler master silent Pro M2 850w
using almost 1 year
