G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.action (More info?)
bk039@ncf.ca (Raymond Martineau) looked up from reading the entrails of
the porn spammer to utter "The Augury is good, the signs say:
>On Wed, 30 Mar 2005 11:00:06 +0100, Andrew <spamtrap@localhost.> wrote:
>>On Wed, 30 Mar 2005 08:53:34 GMT, OldDog <OldDog@city.pound.com>
>>wrote:
>>>Ok, I'm using Agent now. But heck! You all didn't warn me about
>>>ALL the features in it! :-0
>>I did warn you!
>>>I changed a few things around to suit my preferences. But one thing
>>>that I have yet to figure out is how to get it to display the message
>>>vs me having to double click it.
>>>Currently if I hit the N key, I see something like "Msg has 14 lines."
>>>And then I have to double click with mouse to read it.
>>I think you can sort that on out by right clicking on a group name,
>>select Default Properties>Retrieving Messages>Tick "Retrieve bodies
>>for all new messages". There are another load of options you may like
>>to check out in there too 🙂
>That reminds me - is there any way to set that to only download bodies for
>unread messages? I've been setting my killfilter to mark postings as read,
>and using that option auto-downloads those killed messages anyway.
>I do know about the CTRL-N workaround - hold it down, and it queues up all
>other messages for downloading - plus I have a progress indicator on how
>many posts still need to be downloaded.
>Other than this small issue, Agent is perfect.
What you said - no, "read" by definition means you have to have the body
of the message.
What you can do though is ignore the message - then the body will NOT
get downloaded.
Xocyll
I don't particularly want you to FOAD, myself. You'll be more of
a cautionary example if you'll FO And Get Chronically, Incurably,
Painfully, Progressively, Expensively, Debilitatingly Ill. So
FOAGCIPPEDI. -- Mike Andrews responding to an idiot in asr
>>I did warn you!
of the message.
get downloaded.
Xocyll
