E ethanb543 Jun 2, 2018 2 0 10 Jun 2, 2018 #1 I have a watercooler (MasterLiquid ML240L RGB) and I wanted to know if I could power the pump with a normal cpu_fan header or a sys_fan header on the motherboard.
Solution terry4536 Jun 2, 2018 Most closed loop watercoolers are designed to run on a regular 4-pin PWM motherboard fan header. Unless the cooler specifically recommends a higher amp header, then either may be used.
terry4536 Glorious Mar 28, 2010 9,741 6 46,265 Jun 2, 2018 Solution #2 Most closed loop watercoolers are designed to run on a regular 4-pin PWM motherboard fan header. Unless the cooler specifically recommends a higher amp header, then either may be used. Upvote 0 Downvote Solution
