Push power button, turns on 10 minutes later :-/
MrSamsa
4
Howdy
I have an odd problem with my PC powering up that has been bugging me for a while.
When my PC is turned off for a time and I hit the power button it will take up to 10 minutes or so to turn back on. When this first happened I thought the power supply was kaput, so i started sulking while thinking of why it happened and then suddenly it came to life on its own. It was a little unsettling..
I normally leave the PC on 24/7 so this isnt a big problem for me thankfully. Im sure the power supply is adequate for the system and voltages are stable.
Any ideas? I was able to stump my local computer store tech by demonstrating the problem in his workshop :kaola:
There is no physical deformation or damage that is obvious. The PC tech I took it to checked the MB out with one of those mad scientist magnifying glasses.
Are PSU's known to have a charging time? Say its completely discharged.. maybe it needs to charge back up before starting up?
-power supply has a interface to the motherboard that indicates that the power is good. The motherboard can keep a signal to the CPU low until it gets that signal indication of power good. mostly, you can get a delay of 3 or 4 seconds. longer times indicate a problem (pulling too much current, bad powersupply,...)
-some BIOS will try different settings and do a bunch of reboots when overclocking fails. I guess that could take 10 mins.
-Lots of lower quality supplies fake the power good signal, some actually implement it.
-I would check my connections from the power supply to the motherboard and any connections from the power supply to graphics cards and other devices.
if you think you are pulling too much power, you can reduce over clocks, disconnect devices to see if that helps.
-video card can go bad and pull too much power also.
otherwise I would have my power supply checked. (most likely cause)
edit: you indicated you leave the system on all the time. You could have a failure in the startup circuits of the power supply that would not be detected until you power cycle.
