0verzealous May 30, 2023 1 0 10 May 30, 2023 #1 I have an Asus prime b560m-a ac motherboard, and the Cooler master masterfan fan hub, I've checked all of my fans and they're PWM compatible. I've tried using various apps and using a different header for the hub, none of it is working.
jojesa Glorious Dec 6, 2006 7,191 555 47,440 May 30, 2023 #2 Did you connect the SATA power cable to the fan hub and are you connecting the right header (red) to the motherboard PWM fan header?
