q-fan not working with aero 7 hsf...
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
i have an asus A7V8X (bios1012) and a coolermaster AERO7 hsf (w/manual speed
adjustment)
if i manually set the aero7 fan to 3000 RPM (bit noisy) and, enable q-fan in
the BIOS, nothing changes
have set q-fan to 10/15 ratio and 16/32 up/down response time
ps: this used to work when i was using an AMD retail heatsink/fan
tia
>adjustment)
Does it get power directly from the PSU? For Q-Fan to work, the cooler
must get power from the motherboard. I think this cooler is connected
to the motherboard just for monitoring, and gets power from PSU. This
is quite normal for coolers with manual speed adjustment because some
motherboards will report fan failure when the speed change, and some
also when the speed goes below a given speed, e.g. 2000rpm.
Clas Mehus
Dataguiden : http://www.pcworld.no/dataguiden/
"Den som har flest prylar när han dör vinner..."
Latest posts
