Alright, I'm not new to building PCs, but I'm sitting here with a big question mark about mounting the Zalman 9600 fan cooler on my new Gigabyte P35-DQ6.
The support bracket that is supposed to go on the back (solder) side of the motherboard won't seat into the holes because Gigabyte has a big heatsink there, right under the CPU socket!
I'm thinking I'll have to DIY some custom screws and nylon/plastic flat washers in place of the Zalman bracket, just to mount this thing.
Even if I could mount the bracket, the combined thickness of the heatsink + bracket would exceed the clearance provided by the motherboard chassis standoffs.
Surely some of you have already had this combination of motherboard and cooler to work with. What solution worked for you?
