I know I bothered you with my own problems and everything but I just a comment on another forum that a man runs his q6600 4.0GHz cpu at idle 28-30 on load 38, now my temps are similar to this dudes but on stock clock, at 4.0 GHz I am running like 40 idle almost 65 on load(core temps).
My cooling setup is below and a photo if u can see what I am doing wrong.
PS: Please skip comments like reseat the water block and etc, because I tried, maybe either my fans or rads or that kinks out of my res are the problem. I dont know please help.
CPU BLOCK-----------Swiftech Apogee™ GTZ Universal CPU Waterblock
GPU BLOCK----------- EK Radeon HD4850 VGA Liquid Cooling Block
RADIATOR-------------Danger Den Black Ice GT Stealth 240 X-Flow Radiator - Red ***4 of NOCTUA NF-P12 ***
RADIATOR-------------MAGICOOL PRO II 240mm RADIATOR *** 2 case exhaust fans - dodgy brand but they blow ***
PUMP-------------------Swiftech MCP655-B™ 12v Water Pump 1200 L/H
HOSES------------------4 M 1/2 HOSE
PASTE----------- Shin-Etsu X-23-7762 Silicone Thermal Compound - 1g
