..Im Running on a Quad 6600..
I do a lot of Graphic Work..and some gaming and have a Quad6600..nice cpu like it a lot....What arose my Question is my Buddy Just went out and bought a..Cpu e8500 alienware Rig.. also a very nice cpu..like that one alot too..but i started to watch my Temps again on my cpu/gpu because we are going to bench them.... and i realized im running at around 40/40/47/49C and up..and my Gpu (8800GTS) is running around 72.. I do live in a warmer climate..Like today is about 90F.. i was just curious if you guys thought that was too hot..? or if im right around normal temps..? im also on a stock heat sink and it is at stock speeds never overclocked yet.......since my water cooling system i cant get to stop leaking..and got feed up with it.. so i went back to air..
So my Current...Fan Sett up is 😉
2 120mm fans on the top blowing out..
1 120 mm fan on the back blowing out..
1 120 mm fan on the side blowing in on the intake fan of the cpu/ which is Intel Stock.
1 120 mm fan in the front blowin in
and one 80mm fan on the bottom blow in
My case is an cooler master 690..
Other Specs
550Wat Power Cooler Master
2Gigs of DDR2 880 OCZ
Stock Cooling
8800GTS/ Just Scored another for 30$..going to SLI them together
Thanks any Help would be great
Other Specs
Stock Cooling
