hi
i have just built a new computer
Q6600
Asus p5q mobo
zalman 9700 cooler
antec 900 case
stock was at 266 * 9
OC'd to 333 * 9 (3.0 GHz) with 1.29 volts
ran prime95 for 1 hr and stable
idle at 37 C and load at 45 C
i can also OC to 354 * 9 (3.2 GHz) with 1.34 volts
with also 1hr stable on prime95
idles at around 38 C and loads at 52 C
is it safe to OC to 3.2GHz?
is the temperature too high?
and will the high voltage at 1.34 volts shorten the CPU's life span significantly???
thanks
Q6600
Asus p5q mobo
zalman 9700 cooler
antec 900 case
thanks
