quality power supply instead of HKC
not you
1,080
19
19,415
Hello community
I have a HKC 550W psu and there is a problem with it i think
when i push the video card over 40% of its capacity (does not happen usually i play in 900p so the only game that made my computer turn off was Evolve) (gtx 970 g1 gaming) the computer
(i think the video card) gives odd cracking sound and the computer turns off
if i remove the card i see no problem and the card run fine before i put in a better cpu cooler
(this: arctic freezer 13) i think the psu cant handle them now so i want to buy a better (with sli in mind later)
would this be a good choise?
http://www.deepcool.com/product/powersupply/dq/2013-12/33_592.shtml
or this http://www.aqua.hu/seasonic-s12-ii-620w-tapegyseg-191935.html?
my budget can go from 100$ to 200$ (i hope 200 is not needed 😉 ) (if it is 100$ or under i can buy it now if not i have to wait a bit)
thanks for helping me
You want to stay with good brands over more wattage.
Check this list and get Tier 1 or 2 PSUs: http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
or here.
Standard
Bronze
Silver
Gold
Platinum
Titanium
Again, all PSUs are researched by reading professional, unbiased reviews with the correct testing equipment. Some units won't be returning, due to discontinuation and / or too old.
List updated - May 21th 2015
___________________________________________________________________________
\Tier One
The highest quality and most stable Power Supply Units available. Protected by industrial grade protection circuitry and can output wattage at a rated maximum temperature of 50°C or below. These units are also Haswell certified, meaning they can cope with the C6 and C7 sleep states of 0.05Amps without triggering the under-current protection switch. May even go over labelled wattage and still work until it safely shuts down.
Antec High Current Pro Platinum Delta Electronics
Be Quiet
Dark Power Pro P10 / 850w FSP (550w - 750w) / Seasonic (850w - 1200w)
Dark Power Pro P11 850w FSP
Corsair
AX / AXi series 760w - 1200w Seasonic (AX) / Flextronics (AXi)
AX1500i Flextronics
HXi Channel Well Technology
Cooler Master V series / V series 1200w Seasonic
EVGA
SuperNova G2 / P2 / T2 Super Flower
Supernova GS Seasonic
Supernova PS Seasonic
Enermax DigiFanless 500w Channel Well Technology
Firepower Silencer MK3 1200w Super Flower
FSP Aurum PT FSP
LEPA G1600 Enermax
Seasonic
Platinum series Seasonic
Snow Silent 1050w Seasonic
X series / X series XM2 Seasonic
Silverstone Nightjar Platinum 520w Seasonic
Super Flower
Leadex Gold / Platinum Super Flower
Golden King Super Flower
Golden Silent / 430w Super Flower
XFX
Pro series Black edition Seasonic
Pro series Black edition Limited Edition 1000w Seasonic
Pro series XXX / Semi-Modular Seasonic
XTR series Seasonic
XTS Fanless Seasonic
Tier Two
As above, just slightly lower quality. Still safe to use and are all stable for any PC of today's standards, including Haswell C Stepping certification and 100% Japanese Capacitors. It is rare to find a PSU here with Taiwanese Capacitors and perform very well here, but they are here just in case.
Andyson
Platinum-R 1200 Andyson
Titanium N 700w Andyson
Antec
EDGE Seasonic
Earthwatts Delta Electronics/ Earthwatts Platinum FSP
High Current Gamer Delta Electronics (Non-Modular) / Seasonic (Semi-Modular)
Truepower Classic Seasonic (Essentially a Non-Modular version of the EDGE series)
Azza Platinum Super Flower
Be Quiet Straight Power 10 FSP
Cooler Master VS Series Enhance
Corsair RM 850w Channel Well Technology
Enermax Platimax Enermax
EVGA Supernova B2 Super Flower
Firepower
Silencer MK III 400 500 600 / 750 850 Super Flower
ZX Great Wall
Fractal Design Edison M Seasonic
High Power / Sirfa Astro GD Sirfa
Rosewill
Capstone series Super Flower
Lightning series Super Flower
Silent Night 500 Watts Super Flower
Tachyon series Super Flower
Seasonic
G series / G series V2 Seasonic
M12-II EVO (fully modular) Seasonic
S12G (Think of 2011 - 2013 Seasonic G series) Seasonic
S12-II Seasonic
SilentumPC Supremo M1 Gold 550w Sirfa
Silverpower
SP 460w Fully Modular Seasonic
SP Semi-modular Seasonic
Silverstone
Strider Gold Evolution Enhance
Strider Plus 750w 850w 1000w 600w Enhance
Super Flower Golden Green / Modular / HX series Super Flower
Sentey Golden Steel Power 850 Watts Super Flower
Thermaltake
Toughpower Gold 850M Enhance
Toughpower Grand Platinum 850w 1200w Enhance
Toughpower DPS Gold Channel Well Technology
XFX TS 430w / 550w-SEW Seasonic
Right now this is a good PSU:
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($54.99 @ Newegg)
Total: $54.99
Generated by PCPartPicker 2015-05-30 14:05 EDT-0400
This is another good one and it is a 650w. Depending on your other parts get the 550w.
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($59.99 @ Newegg)
Total: $59.99
Generated by PCPartPicker 2015-05-30 14:10 EDT-0400
The fact you heard crackling is a strong indicator your PSU is failing, please do not use your PC until you replace that unit with a quality one. If it dies completely which it could do now even with light load it coil cause significant damage. I'm not trying to scaremonger but I wouldn't want you to loose the rest of your system.
thiese ones any good?
http://www.arukereso.hu/tapegyseg-c3158/xfx/core-edition-80-750w-proseries-p1-750s-nlb9-p44454611/
http://www.arukereso.hu/tapegyseg-c3158/xfx/pro-series-750w-xxx-edition-p1-750x-xxb9-p149171265/
http://www.arukereso.hu/tapegyseg-c3158/xfx/pro-series-850w-xxx-edition-p1-850x-xxb9-p149171263/
Any of those XFX units are good, Excellent build quality and stability.
If you can find a 550w XFX for cheaper, It would be ideal. You do not need anything more than 500w for a GTX 970 system, and 750w for a 970 SLI setup
and also has no problems when playing a bit less intensive game like dying light (also maxed) it gives strange sound but dont turn off when playing shadow of mordor (also maxed) only turns off if i play Evolve
if this is not g2 in the shop http://www.arukereso.hu/tapegyseg-c3158/evga/supernova-750w-g2-110-b1-0750-vr-p234168127/
i will buy this one http://www.arukereso.hu/tapegyseg-c3158/xfx/pro-series-850w-xxx-edition-p1-850x-xxb9-p149171263/
since its cheaper than this http://www.arukereso.hu/tapegyseg-c3158/xfx/proseries-750w-p1-750g-ts3x-p247931907/
good choise?
